Static IP adress
Static IP adress
hello, i'm a newbi in linux distribution . please, how can i give a static ip to the nagiosXI VM?
Re: Static IP adress
Hello and welcome, there is a tutorial video regarding this here:
http://www.youtube.com/watch?v=0tZcrM4rpqY
thanks for the link
.. but i got this when a try the command : "system config network"
Run in terminal:
Hope this helps.
yum install system-config-network -y
system-config-networkBe sure to check out our Knowledgebase for helpful articles and solutions!
I'm glad I could help!
