events correlation
Post Reply
wolfgang
events correlation
Post by wolfgang »
hi everybody,
first, i have installed Nagios Core but i don't find an adequate forum
i need to have a real correlation "motor" .
The rules in Nagios are insufficient.
for example, i want to :
* when a router is down, i don't want to receive alerts from all hosts
* i want to be able to run script on alert
* i want to be able to modify some old events and resend them or others in the correlation's motor
etc......
So, if i want to write complex rules, can i plug NagiosLogAnalyzer and do correlation with NagiosLogAnalyzer fromevents coming from logs and from events coming from Nagios.
Is it possible ?
and how ?
Best regards
T Granier
bbahn
Re: events correlation
Post by bbahn »
Hello @wolfgang,
You CAN actually make it so that you only receive one alert when your router is down instead of everything. By setting parent/child relationships, if a parent host goes down, the child nodes will not have notifications sent.
You CAN have a script run on alert with the event handlers system.
I'm not sure what you mean by
. Can you elaborate?
Post Reply
