Bug: scheduled backups not available in UI 2026R1
Post Reply
wneville
Post by wneville »
I cannot access the scheduled backups portion of the UI. I get this message:
Error: This component requires the pecl ssh2 module. You must run install.sh in /usr/local/nagiosxi/html/includes/components/scheduledbackups as root to use this component.
However, pecl/ssh2 is already installed. Confirmed by running install.sh:
make[1]: Leaving directory '/usr/local/nagiosxi/html/includes/components/scheduledbackups/libssh2-1.10.0'
pecl/ssh2 is already installed and is the same as the released version 1.4.1
install failed
NagiosXI version 2026R1
wneville
Re: Bug: scheduled backups not available in UI 2026R1
Post by wneville »
Resolved that, but my other server cannot send its backups over to this one, it even fails the "Test Connection" button in the UI. I can confirm ssh on the command line from server to server is working as expected. "Test Connection" generates this message "Could not establish a connection to [IP]
This just started failing last week, had been working for months prior to that
Post Reply
