Nagiosxi Network Switch / Router wizard no Port Statistics
Post Reply
vtcedu
Post by vtcedu »
As title we found the Nagiosxi Network Switch / Router wizard no Port Statistics but Nagiosxi version 5.5.8 have.
cdepaulis
Re: Nagiosxi Network Switch / Router wizard no Port Statistics
Post by cdepaulis »
The Port Statistics no longer being there is intended behavior. I am unsure of the reason or when it got removed.
If you have any more questions or concerns let me know.
- Caleb
atheson
Post by atheson »
Use the SNMP Walk Wizard: This is now the recommended way to find specific statistics (like
ifInErrors
or
ifOutDiscards
) that are no longer "one-click" in the Switch/Router wizard. You can walk the device and select the exact statistic OIDs you want to monitor.
Manually Update the Wizard: If you have a backup of your old 5.5.8 instance, you can export the older
switch.zip
wizard file from Admin > Manage Config Wizards and try uploading it to your new system.
Note: Be careful with this, as older wizards may not be fully compatible with the newer PHP versions or the Neptune UI used in Nagios XI 2024+.
Post Reply
