How can I detect if an apply config is needed from cli
Post Reply
StevenBeauchemin
Post by StevenBeauchemin »
I can see in CCM when the system wants an Apply Config.
How can I tell from the command line if an Apply Config is needed?
Steve B
kg2857
Re: How can I detect if an apply config is needed from cli
Post by kg2857 »
If you haven't made a change in CCM or dropped anything in the import dir there's no need to reconfigure.
cdietsch
Post by cdietsch »
Hi Steve,
I don't think there is a builtin command but I know you can run the following SQL query:
SELECT value FROM nagiosxi.xi_options WHERE name = 'ccm_apply_config_needed';
And it will output either 0 or 1.
You could write a shell script to run query and parse the output.
Cheers,
- Cole
Post Reply
