SQL Error [nagiosxi] : Table 'nagiosxi.xi_sso_mappings' doesn't exist
Post Reply
op-team
Post by op-team »
Since i have upgraded Nagios XI 2024R2 to 2026R1.1, we have "SQL Error [nagiosxi] : Table 'nagiosxi.xi_sso_mappings' doesn't exist" after clicking on "Manage Users" from web interface
How can I solved this?
Many thanks
lgute
Re: SQL Error [nagiosxi] : Table 'nagiosxi.xi_sso_mappings' doesn't exist
Post by lgute »
Hi @op-team,
Thanks for reaching out.
This issue was reported in another thread. You can try manually applying the schema file, as suggested by @bbahn.
@bbahn also theorizes this may be a larger upgrade issue. If that is the case please open a ticket with our Technical Support team at https://support.nagios.com/.
-Laura
Post Reply
