check_insight_agents
steelah1
Post by steelah1 »
Is there anyway to use this with hpux? I'm running an hp9000 w hpux 11.31, hp's version of snmp and system insight manager, and check_insight_agents 2.0 plugin. It queries windows boxes fine, but the oid's appear different for hpux. I can query things like memory usage, disk space, cpu, etc., but I can't query hardware. Is there a nagios plugin, or a set of oid's to query snmp on hpux with check_snmp?
Re: check_insight_agents
Post by slansing »
Sorry this post is rather old, if you are still having issues can you link where this plugin is? It cannot be found on the Exchange.
