Failed Upgrade to 2026R1.2
Post Reply
wneville
Post by wneville »
Tried to upgrade to the latest and greatest this morning, looking forward to SSO improvements - I errored out with the following (RHEL):
UPGRADE: Nagios Core upgraded OK.
Building InfluxDB performance data module...
gcc -I.. -fPIC -I. -I../include -I.. -I../include -I../lib  -g -O2  -DHAVE_CONFIG_H -o influx_perf_api_v1.o ./influx_perf_api_v1.c -shared  -lssl -lcrypto  -lcurl -lpthread
./influx_perf_api_v1.c:57:10: fatal error: curl/curl.h: No such file or directory
 #include <curl/curl.h>
compilation terminated.
make: *** [Makefile:37: influx_perf_api_v1.o] Error 1
Error: make command failed
Anyone else see this?
kfanselow
Re: Failed Upgrade to 2026R1.2
Post by kfanselow »
Hi Will,
It looks like libcurl-devel package isn't installed. For an EL based system run the following as root and then retry the upgrade.
dnf install libcurl-devel -y
For a Debian or Ubuntu system you'll want to run the following (as root) and retry the upgrade.
apt-get install libcurl4-openssl-dev
Thanks and have a great rest of you day,
Keith
Alongaks
Post by Alongaks »
wneville wrote: Wed Feb 25, 2026 8:23 am Tried to upgrade to the latest and greatest this morning, looking forward to SSO improvements - I errored out with the following (RHEL):
Yep. Had the same issue 2026R1.1 -> 2026R1.2.
Doing the libcurl-devel install fixed it. Not sure if this was mentioned in the email blasts or release notes about the new version.
wneville
Post by wneville »
I'm all set!! Thank you both!
liambrown32
Post by liambrown32 »
Had the same error on a fresh upgrade recently. Installing libcurl-devel fixed it right away for me too.
Feels like this dependency should probably be called out more clearly in the upgrade notes, especially since the error isn’t super obvious if you haven’t hit it before.
Post Reply
