Custom Alert for High CPU on Virtual Machines
Post Reply
sophia2005
Post by sophia2005 »
Hi all, I’m trying to create a custom alert in Nagios XI that triggers only when a virtual machine’s CPU usage stays above 85% for more than 10 minutes. I’ve tried using standard thresholds, but it seems to trigger immediately. Is there a recommended way to set up a delayed or sustained CPU usage alert specifically for VMs?
DoubleDoubleA
Re: Custom Alert for High CPU on Virtual Machines
Post by DoubleDoubleA »
What are your settings for
check_interval
retry_interval
max_check_attempts
Post Reply
