New Install of Nagios XI 2026R1.4 missing hosts
matson-itops
Post by matson-itops »
Brand new install, I added 3 hosts in CCM . but host status still showing zero hosts
what am I missing?
matson-itops
Re: New Install of Nagios XI 2026R1.4 missing hosts
update : service checks work fine, but no hosts and no services show up.
kg2857
Post by kg2857 »
Dumb question but did you apply the changes in ccm?
laurajames9010
Post by laurajames9010 »
From my experience, this usually happens if you haven’t applied the configuration yet in CCM, so try clicking Apply Configuration and restarting Nagios to update the host status. basketball stars
matson-itops
yes. several times with several attemps.
applied config is good, I get alerts, etc. just do NOT see it in "host status" or " service status"
bbahn
Post by bbahn »
Fresh installs of Nagios XI should have localhost as a host already configured. Are you saying you don't see this? This makes me think you likely have a database error. In /usr/local/nagiosxi/scripts, there will be a repair_databases.sh script that you can run that usually fixes issues like these. Repairing the Nagios XI 2024 Databases
Since you're on a new install, if this doesn't solve your problem, I'd recommend starting over as something likely went wrong during the installation process.
matson-itops
bbahn wrote: Wed Apr 29, 2026 10:20 am Fresh installs of Nagios XI should have localhost as a host already configured. Are you saying you don't see this? This makes me think you likely have a database error. In /usr/local/nagiosxi/scripts, there will be a repair_databases.sh script that you can run that usually fixes issues like these. Repairing the Nagios XI 2024 Databases
thanks for the suggestion. no errors during install.
matson-itops
Looks like ndo3 is required, but it was not installed on a fresh box along
with nagiosXI
is it required? ndo2 is not there either.
DoubleDoubleA
Post by DoubleDoubleA »
NDO3 is required, it is surprising it was not installed. We don't ship NDO2 these days.
Do you have access to install.log? In any case, NDO3 in a NEB module, it should have compiled and loaded when the monitoring engine started.
What version of XI are you coming from?
kfanselow
Post by kfanselow »
Hi matson-itops,
Could you show us the broker line from your nagios.cfg ?
grep "^broker" /usr/local/nagios/etc/nagios.cfg
And confirm the status of nagios core:
systemctl status nagios
Do you see a change in the interface after running the following ?
/usr/local/nagiosxi/scripts/reconfigure_nagios.sh
Thanks and best regards
Post Reply
