trimmin the log.
benhank
trimmin the log.
Post by benhank »
is there a way to have nagios limit the size of its log files?
Proudly running:
Nagios Network Analyser
Nagios Fusion
Re: trimmin the log.
Post by slansing »
The Nagios system automatically archives the logs and it needs them in that archive for various reports. So it is not really recommended to fiddle around with changing or limiting the Nagios system's log's.
benhank
Post by benhank »
I was thinking more of the event logs. We once screwed up notifications and ended up with a 20gig log file ...4 of them
Proudly running:
Nagios Fusion
mguthrie
Post by mguthrie »
You can't really limit the log size, just the frequency of the rotation, which is in the main nagios.cfg file. You can however turn off some of the logging features so that less data gets logged. This will actually help performance if you don't need the data.
log_event_handlers=0
log_notifications=0
log_passive_checks=0
log_service_retries=0
log_host_retries=0
benhank
Post by benhank »
excellent! that's just what I needed!
Proudly running:
Nagios Fusion
