Any way to clear host settings?
jbennett
Post by jbennett »
I'm wondering if there's any way to easily clear check and alert settings on hosts and services?
A number of my hosts and services have these fields set AND have a template applied to them.
I'm under the impression that if these fields are set in the host/service, then that setting will over ride the template, correct?
In order to verify that my checks are what I think they are, I would like to know if there's an easy way to do this without having to go to each individual item.
Re: Any way to clear host settings?
In the 2012 version you can make modifications in bulk at
Configure -> CCM -> Tools -> Bulk Modifications -> Change a single config option
jbennett
Post by jbennett »
scottwilkerson wrote:In the 2012 version you can make modifications in bulk at
I'm guessing this is in the CCM Beta?
Also, is there a difference between leaving the field blank and saving it and setting the field to 0 and saving it?
Will a blank field overwrite anything in the fields?
jbennett wrote: Also, is there a difference between leaving the field blank and saving it and setting the field to 0 and saving it?
Yes there is a difference between blank and 0
blank will use any values set in underlying templates, whereas 0 will set the host/service level to 0 and will use that instead of what is in underlying templates
jbennett
Post by jbennett »
It appears that even leaving it as blank for the bulk modification, it will put a 0 in. I'm not sure if there's a newer version of the CCM beta? I'm on .3 currently.
mguthrie
Post by mguthrie »
This is a known bug in earlier versions of the beta, but is fixed in the 2012 release.
