Nagios send me notification but it only has last line founded in log. When i check service on www, there is list of all error lines.
How i can change configuration to send me all wrong lines?
I tried to add LONGSERVICEOUPUT in contact command, but id doesn't work.
(In check_logfiles, i type "long")
Please help
serviceoutput from check_logfiles
Re: serviceoutput from check_logfiles
I'm not sure I fully understand the problem, are you able to post a picture of the full status output from Nagios and the message you are receiving? If you could also post your contact command definition as well that would probably help.
Hi
thank you for your reply!
I found how do that:
$SERVICEOUTPUT$$LONGSERVICEOUTPUT$
glad you worked it out!
