Capacity planning reports
lafargeuser
I have installed Nagios XI 2012R1.0 on CentOS release 5.3.
Now i would like to generate below types of reports.
Average CPU Utilisation %
RAM Avg Used (GB) Avg % Used
Hard disk Avg Used (GB) Free (GB) % Used
C:\ (1)
D:\ (2)
Group CPU utilization
Group disk utilization
In metrics tab i can see similar details. Which had mentioned above. But didnt see any option to export in pdf or Excel format.
Moreover, i didnt see any date range for generating reports.
Is there any plugin available or this can possible with my current XI 2012R1.0 ?
C:\ (1)
D:\ (2)
Re: Capacity planning reports
Did you try the capacity planning report?
lafargeuser
Yes. I did. But its saying......
This feature is part of the Enterprise Edition of Nagios XI. Start your 60-day trial of Enterprise Edition features now to enable full functionality. Learn more about upgrading to Enterprise Edition.
If you click on " Start your 60-day trial" you can enable the full features of the Enterprise Edition for 60 days to see if this will meet your needs.
lafargeuser
Yeah. Thanks.
Can i generate repots in PDF or any other format ?
I cant see any other option than schedule this report,email report & add to report.
This particular report cannot be generated as a pdf at this time because it is interactive...
lafargeuser
It seems like trial period is expired.
This feature is part of the Enterprise Edition of Nagios XI. Your trial of this feature has expired. Some functionality may be limited or disabled. Learn more about upgrading to Enterprise Edition.
Will you pls. share some sample reports. Fetched using capacity planning.
e.g. Mem & CPU in Avg % utilization.
Sure take a look at the attached images.
lafargeuser
Thanks.
But, I dont see Average CPU Utilisation % & RAM Avg Used (GB) Avg % Used (Monthwise).
Can I get that in Capacity planning reports ?
While you can use Capacity planning for this "Extrapolating data from a month ago," this is not the direct function of the system. It is for future projections, the Graph Explorer would be something more along the lines you are looking for. I have supplied a couple new screen shots the first one is a 4x4 extrapolation. For memory, it will only show the direct amount used because of how your OS tasks it, however CPU will show percentage.
