\Upgrade to Nagios XI 2012R1.0
rdhall01
Post by rdhall01 »
I had a few errors in the upgrade process, but able to work thru most them until this issue! If I click on the Icon for Scedule page I receive the following error.
The requested URL /nagiosxi//includes/components/scheduledreporting/schedulereport.php was not found on this server.
on the server I see
[act@server components]# pwd
/usr/local/nagiosxi/html/includes/components
[act@server components]# ls
autodiscovery componenthelper.inc.php customlogo jpgraph nagioscore nagiosql perfdata profile xicore
ccm cp highcharts latestalerts nagioscorecfg pchart pnp response
no scheduledreporting directory
So Iam not sure if the upgrade fully worked or not
Re: \Upgrade to Nagios XI 2012R1.0
It seems your upgrade didn't go like it was supposed to. Try running the "./upgrade" again, and post what is on the screen (the last output) after the upgrade is done.
rdhall01
Post by rdhall01 »
RET: 0
Running configuration check...done.
Stopping nagios: .done.
Starting nagios: done.
Archive: sourceguardian/ixed4.lin.x86-64.zip
inflating: /usr/lib64/php/modules/ixed.5.3.lin
Sourceguardian extension found for PHP version 5.3
Sourceguardian extension already in php.ini
UPGRADE COMPLETED!
Logout of the Nagios XI interface and log back in as 'nagiosadmin' to complete the upgrade.
You can access the Nagios XI web interface by visiting:
http://xxx.xxx.xxx.xxx/nagiosxi/
Do you have more components now, or there is no change?
What are the permissions on the components directory? Run the following command and show us the output:
ls -ld /usr/local/nagiosxi/html/includes/components
rdhall01
Post by rdhall01 »
after running the command
results
drwxr-x--- 51 nagios nagios 4096 Oct 17 13:43 /usr/local/nagiosxi/html/includes/components
components are now there at least the schedule page is now displayed correctly
I'm glad I could help. :)
