Nagios Core as a dashboard
Can Nagios function as a dashboard via integration with a third party tool like CA Spectrum? How can this occur?
Re: Nagios Core as a dashboard
Yes? Can you be a little more specific as to what you'd want it to do? There's not really enough information there...
- inventsekar
i assume you wanted to integrate Nagios and CA Spectrum and use Nagios as the dashboard... i mean, monitoring will be done by CA Spectrum, alerts dashboard will be Nagios GUI, is that correct?
Yes, as Mguthrie said, it should be possible and In fact, Nagios GUI is super simple and its user-friendly (unlike nagios's configuration
inventsekar is correct. Is Nagios GUI a separate product or is it part of Core or XI? Also, since Spectrum uses SNMP to collect data, how would Nagios GUI collect the data?
- inventsekar
Nagios GUI is a part of Nagios Core(as well as Nagios XI). Its simple to install Nagios Core thru the quickstart install guides (the installation may take less than ten mins if you dont get compiler errors), at the end of the quick start installation procedure, you will get the GUI ready.
SNMP integration plugins are there at exchange (exchange.nagios.com i think )
thanks...
thanks...
