After reboot NagVis gives blue buttons
fogier
Post by fogier »
Details:
Nagios Version: Nagios v3.3
NagVis Version: NagVis v1.7
Infrastructure: vSphere v4.1 virtual machine (1vCPU, 2GB RAM)
When we reboot our Nagios XI server and it comes back all the icons within NagVis are blue (see screenshot 1).
Also after a reboot the hosts have a gray background (see screenshot 2).
A workarround is to apply the configuration within the Nagios Core Configurator. Then all is repaired and works.
In screenshot 3 you can see that the service mentoined in screenshot 1 is there and worked with Nagios.
We've got 2 Nagios-servers and both servers have this problem.
What to do?
1.
2.
3.
Re: After reboot NagVis gives blue buttons
Can you post your nagios.cfg
fogier
Post by fogier »
Sorry for the late answer, but I don't get emails anymore from you guys. I need to subscribe myself to my own posts. ;)
Here is our nagios.cfg
# MODIFIED
admin_email=root@localhost
admin_pager=root@localhost
translate_passive_host_checks=1
log_event_handlers=0
use_large_installation_tweaks=1
enable_environment_macros=0
# NDOUtils module
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
# PNP settings - bulk mode with NCPD
process_performance_data=1
# service performance data
service_perfdata_file=/usr/local/nagios/var/service-perfdata
service_perfdata_file_template=DATATYPE::SERVICEPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tSERVICEDESC::$SERVICEDESC$\tSERVICEPERFDATA::$SERVICEPERFDATA$\tSERVICECHECKCOMMAND::$SERVICECHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tSERVICESTATE::$SERVICESTATE$\tSERVICESTATETYPE::$SERVICESTATETYPE$\tSERVICEOUTPUT::$SERVICEOUTPUT$
service_perfdata_file_mode=a
service_perfdata_file_processing_interval=15
service_perfdata_file_processing_command=process-service-perfdata-file-bulk
# host performance data
host_perfdata_file=/usr/local/nagios/var/host-perfdata
host_perfdata_file_template=DATATYPE::HOSTPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tHOSTPERFDATA::$HOSTPERFDATA$\tHOSTCHECKCOMMAND::$HOSTCHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tHOSTOUTPUT::$HOSTOUTPUT$
host_perfdata_file_mode=a
host_perfdata_file_processing_interval=15
host_perfdata_file_processing_command=process-host-perfdata-file-bulk
# OBJECTS - UNMODIFIED
#cfg_file=/usr/local/nagios/etc/objects/commands.cfg
#cfg_file=/usr/local/nagios/etc/objects/contacts.cfg
#cfg_file=/usr/local/nagios/etc/objects/localhost.cfg
#cfg_file=/usr/local/nagios/etc/objects/templates.cfg
#cfg_file=/usr/local/nagios/etc/objects/timeperiods.cfg
# STATIC OBJECT DEFINITIONS (THESE DON'T GET EXPORTED/IMPORTED BY NAGIOSQL)
cfg_dir=/usr/local/nagios/etc/static
# OBJECTS EXPORTED FROM NAGIOSQL
cfg_file=/usr/local/nagios/etc/contacttemplates.cfg
cfg_file=/usr/local/nagios/etc/contactgroups.cfg
cfg_file=/usr/local/nagios/etc/contacts.cfg
cfg_file=/usr/local/nagios/etc/timeperiods.cfg
cfg_file=/usr/local/nagios/etc/commands.cfg
cfg_file=/usr/local/nagios/etc/hostgroups.cfg
cfg_file=/usr/local/nagios/etc/servicegroups.cfg
cfg_file=/usr/local/nagios/etc/hosttemplates.cfg
cfg_file=/usr/local/nagios/etc/servicetemplates.cfg
cfg_file=/usr/local/nagios/etc/servicedependencies.cfg
cfg_file=/usr/local/nagios/etc/serviceescalations.cfg
cfg_file=/usr/local/nagios/etc/hostdependencies.cfg
cfg_file=/usr/local/nagios/etc/hostescalations.cfg
cfg_file=/usr/local/nagios/etc/hostextinfo.cfg
cfg_file=/usr/local/nagios/etc/serviceextinfo.cfg
cfg_dir=/usr/local/nagios/etc/hosts
cfg_dir=/usr/local/nagios/etc/services
# GLOBAL EVENT HANDLERS
global_host_event_handler=xi_host_event_handler
global_service_event_handler=xi_service_event_handler
# UNMODIFIED
accept_passive_host_checks=1
additional_freshness_latency=15
auto_reschedule_checks=0
auto_rescheduling_interval=30
auto_rescheduling_window=180
bare_update_check=0
cached_host_check_horizon=15
cached_service_check_horizon=15
check_external_commands=1
check_for_orphaned_hosts=1
check_for_orphaned_services=1
check_for_updates=1
check_host_freshness=0
check_result_path=/usr/local/nagios/var/spool/checkresults
check_service_freshness=1
command_check_interval=-1
command_file=/usr/local/nagios/var/rw/nagios.cmd
daemon_dumps_core=0
date_format=us
debug_file=/usr/local/nagios/var/nagios.debug
debug_level=0
debug_verbosity=1
enable_embedded_perl=1
enable_event_handlers=1
enable_flap_detection=1
enable_notifications=1
event_broker_options=-1
event_handler_timeout=30
execute_host_checks=1
execute_service_checks=1
external_command_buffer_slots=4096
high_host_flap_threshold=20.0
host_check_timeout=30
interval_length=60
lock_file=/usr/local/nagios/var/nagios.lock
log_external_commands=0
log_file=/usr/local/nagios/var/nagios.log
log_host_retries=1
log_initial_states=0
log_notifications=1
log_passive_checks=0
log_rotation_method=d
log_service_retries=1
low_host_flap_threshold=5.0
max_check_result_reaper_time=30
max_concurrent_checks=0
max_debug_file_size=1000000
max_host_check_spread=30
max_service_check_spread=30
nagios_group=nagios
nagios_user=nagios
notification_timeout=30
object_cache_file=/usr/local/nagios/var/objects.cache
obsess_over_hosts=0
obsess_over_services=0
ocsp_timeout=5
p1_file=/usr/local/nagios/bin/p1.pl
perfdata_timeout=5
precached_object_file=/usr/local/nagios/var/objects.precache
resource_file=/usr/local/nagios/etc/resource.cfg
retain_state_information=1
retention_update_interval=60
service_check_timeout=60
service_interleave_factor=s
sleep_time=0.25
soft_state_dependencies=0
state_retention_file=/usr/local/nagios/var/retention.dat
status_file=/usr/local/nagios/var/status.dat
status_update_interval=10
temp_file=/usr/local/nagios/var/nagios.tmp
temp_path=/tmp
use_embedded_perl_implicitly=1
use_regexp_matching=0
use_retained_program_state=1
use_syslog=1
use_true_regexp_matching=0
Have you offloaded your MySQL server? If so you may need to reconfigure
Open -> WUI -> Options -> Manage Backends
fogier
Post by fogier »
No, MySQL runs locally.
I believe we may be getting in a race condition on reboot that is starting the nagios process before ndo2db.
I have only seen this in one other instance and it was worked around by adding the following to
/etc/rc.local
service nagios restart
fogier
Post by fogier »
It's been a long time since a paided attention to Nagios due to other work.
I've tried your workarround but it doesn't work. Blue bottons are staying after a reboot or cold startup.
abrist
Red Shirt
Post by abrist »
Make sure the edit to /etc/rc.local is correct. The next time you reboot your system, once it is fully loaded, copy the output of:
tail -100 /var/log/messages
tail -100 /usr/local/nagios/var/nagios.log
And post them here or pm them to one of the nagios support staff on the forums here. There is a good chance we need to get a longer delay on the restart of nagios after system boot.
fogier
Post by fogier »
In the meantime we've downloaded a fresh install of Nagios because we wanted to run on a x64 system.
The problem is now gone! Thanks.
abrist
Red Shirt
Post by abrist »
Great! Enjoy the new word length. Locking 'er up.
