I deleted some hosts and the services related to them. I applied the configuration and performed the steps in CCM-Tools- Write Config Files but those hosts have not been deleted from the configuration. I do not see the hosts in CCM-Hosts but when I check in Home- Host Detail, I still see them. Does it take some time to delete the host in the main config? Please let me know.
Thank you,
Deepika Manem
Config update
Re: Config update
It shouldn't. What version of Nagios XI are you using?
Re: Config update
we have seen this on occasion, one possibility is outlines in this FAQ
http://support.nagios.com/wiki/index.ph ... t_Hosts.29
Re: Config update
Thank you. I manually deleted the config files.
Regards,
Deepika
Regards,
Deepika
