Fusion Upgrade problems
This support forum board is for questions relating to Nagios Fusion.
arnab.roy
Post by arnab.roy »
Hi Mike,
I upgraded our 2012R1.0 install to 2012R1.3 and the upgrade ends in a bit of a snag
PHP Warning: Module 'SourceGuardian' already loaded in Unknown on line 0
Archive: sourceguardian/ixed4.lin.x86-32.zip
checkdir: cannot create extraction directory: /usr/lib/php/modules
No such file or directory
No valid Sourceguardian extension found for PHP version 5.3
Although the upgrade works...I guess...as everything loads ok...
Many Thanks
Arnab
mguthrie
Re: Fusion Upgrade problems
Post by mguthrie »
I've seen something similar on XI installs where php was upgraded after the initial installation. Any chance there was a similar situation here?
What's the distro information for the install and php version?
I'll keep my eyes peeled and see if that shows up elsewhere.
