check_local_swap parameters incorrect in localhost.cfg
The warning and critical parameters specified in the sample localhost.cfg should be 10% and 5% and not 10 and 5 (which indicate bytes free)
Re: check_local_swap parameters incorrect in localhost.cfg
You may need to provide this feedback on the nagios core developer mailing list... the projects code contributors don't really visit this forum.
Thanks, I gave up trying to find the appropriate link on the Nagios website and opted to at least report it here!
In the big scheme of things, it's probably not a big deal.....if I ever find the mailing list I will certainly report it there too.
