Problem restarting nagios
anaigini45
Post by anaigini45 »
I am a newbie in Nagios. I installed nagios, and nagiosgraph. It worked initially, when I ran it on the browser (http://localhost/nagios). However, while configuring some *.cgi files for nagiosgraph, I accidently corrupted all those files, including the ones that belonged with nagios. Therefore I wasn't able to view services and hosts, etc etc in nagios.
I removed and reinstalled nagios and its dependencies. However, when I reach the part to restart nagios, I fail to get pass it. This is the error that I receive :
aigini@aigini-Studio-1555:/usr/local/nagios/etc$ service nagios start
Starting nagios:CONFIG ERROR!  Start aborted.  Check your Nagios configuration.
I even tested nagios cfg with this command :
aigini@aigini-Studio-1555:/usr/local/nagios/etc$ sudo /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 3.3.1
Last Modified: 07-25-2011
License: GPL
Reading configuration data...
   Read main config file okay...
Processing object config file '/usr/local/nagios/etc/objects/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/templates.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/localhost.cfg'...
Checking services...
	Checked 8 services.
Checking hosts...
	Checked 1 hosts.
Checking host groups...
	Checked 1 host groups.
Checking service groups...
	Checked 0 service groups.
Checking contacts...
	Checked 1 contacts.
Checking contact groups...
	Checked 1 contact groups.
Checking service escalations...
Checking service dependencies...
	Checked 0 service dependencies.
Checking host escalations...
	Checked 0 host escalations.
Checking host dependencies...
	Checked 0 host dependencies.
Checking commands...
	Checked 24 commands.
Checking time periods...
	Checked 5 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 0
Total Errors:   0
It says no errors. But why do I still get an error when I attempt to start nagios?
I tried looking for nagios error logs but could not find any. Please help.
jsmurphy
Re: Problem restarting nagios
Post by jsmurphy »
If you look in /usr/local/nagios/var/nagios.log there should be some information as to why it's failing.
ajuhamza
Post by ajuhamza »
Can you try starting nagios daemon by giving:
#/usr/local/nagios/bin/nagios -c /usr/local/nagios/etc/nagios.cfg -d
I think while recompiling, there might have been some problem with the init script for starting Nagios daemon.
