Error : could not open command file /usr/local/nagios/var/rw
Getting error
Error : could not open command file /usr/local/nagios/var/rw/nagios.cmd
for update.
The permission on extrnal command file and or dir may b incorct.
Error ocourd whle attmptng to commit
for update.
Re: Error : could not open command file /usr/local/nagios/va
Can anyone reply this
Change the ownership for the directory with the following:
chmod +rwx /usr/local/nagios/var/rwRe: Error : could not open command file /usr/local/nagios/va
Still same error.
Can you run the following and report the output back here:
Additionally can you send a copy of your nagios.cfg file, it is locate at:
ls -ld /usr/local/nagios/var/rw/Additionally can you send a copy of your nagios.cfg file, it is locate at:
/usr/local/nagios/etc/nagios.cfgRe: Error : could not open command file /usr/local/nagios/va
Nagios recreates that file after each restart, so updating permissions from the system won't fix that. What are the permissions on that file?
Are external commands enabled in the main nagios.cfg file?
check_external_commands=1
Look at the last page of this guide where you can find the correct sequence of command to submit
http://giuseppeturri.it/NAGIOS_INSTALLATION_GUIDE.pdf
Let me know
Let me know
Is apache member of nagcmd group?
cat /etc/group | grep nagBe sure to check out our Knowledgebase for helpful articles and solutions!
I believe that the correct command would be:
and
usermod -G nagios apacheCode: Select all
usermod -G nadcmd apacheRe: Error : could not open command file /usr/local/nagios/va
Thread is incredibly old so I will be closing this now.
