NagiosXI 2012R1.1 Upgrade problem
alder
Post by alder »
I'm currently running NagiosXI 2012R1.0. I follow the upgrade instructions and everything goes fine. I see the following:
Total Warnings: 0
Total Errors: 0
RET: 0
Running configuration check...done.
Stopping nagios: done.
Starting nagios: done.
Archive: sourceguardian/ixed4.lin.x86-32.zip
inflating: /usr/lib/php/modules/ixed.5.3.lin
Sourceguardian extension found for PHP version 5.3
Sourceguardian extension already in php.ini
UPGRADE COMPLETED!
Logout of the Nagios XI interface and log back in as 'nagiosadmin' to complete
the upgrade.
When I go back to the web browser however and login as nagiosadmin, I see nothing to finish the upgrade. I try Shift+Reload page and still get same thing. Have logged in/out several times now. Tried 3 different browsers. Any ideas?
Re: NagiosXI 2012R1.1 Upgrade problem
We are looking into why the latest files didn't update.
For now you can download the current version from
http://assets.nagios.com/downloads/nagi ... 1.1.tar.gz
alder
Post by alder »
That worked thanks!
