Problem viewing service check details in IE8 for R1.1
whjsmith
Post by whjsmith »
We just upgraded to Nagios XI 2012 version 1.1 and noticed that service check details do not display properly in IE8. It displays the information for every tab on the same page. I have provided the screenshot below. Let me know if you need any further information.
Our installation is currently:
CentOS Linux release 6.0 (Final)
32 bit
VM Image
Special Configurations: No
mguthrie
Re: Problem viewing service check details in IE8 for R1.1
Post by mguthrie »
Try clearing your cached javascript files, and also right-clicking and selecting refresh to make sure the new javascript updates are being applied. In testing this locally we haven't been able to recreate this browsing in IE8 mode.
Is compatibility mode turned on? If so try turning it off and see if that fixes the issue.
