2012R1.1 version add contacts not working
perryell
Post by perryell »
I installed 2012R1.1 (oct 5 vm 64 bits). Updated with OCt 25 upgrade.
I created some users with contact without problem
After i tried to create some contacts..configure--core configuration manger--contacts--Add new
I try with a test user with the required fields and email , active check mark, configuration saved
No message back of contact added succesfully, just blank screen. Going back to contacts menu, and user never added
Delete contact works perfect, but i can't add the contact back after deletion
Add contracts group works too
Ileana
Re: 2012R1.1 version add contacts not working
Yep, this is a bug relating to out adding Internationalization to the Nagios XI code.
Edit /usr/local/nagiosxi/html/includes/components/ccm/includes/contact.inc.php
change this on line 278
if ($errors > 0) $strMessage .= gettext("There were ").$errors.gettext(." errors while processing this request")."<br />".$myDataClass->strDBMessage;
to this
if ($errors > 0) $strMessage .= gettext("There were ").$errors.gettext(" errors while processing this request")."<br />".$myDataClass->strDBMessage;
Or unzip the attached file and replace /usr/local/nagiosxi/html/includes/components/ccm/includes/contact.inc.php
perryell
Post by perryell »
Working now, thanks!
