Nagios XI Installation Profile
Download Profile
System:
Nagios XI Version : 2012R1.1
nagprod01.cellnet.com 2.6.32-220.23.1.el6.x86_64 x86_64
CentOS release 6.2 (Final)
Gnome is not installed
Apache Information
PHP Version: 5.3.3
Agent: Mozilla/5.0 (Windows NT 6.1; rv:16.0) Gecko/20100101 Firefox/16.0
Server Name: 148.80.140.92
Server Address: 148.80.140.92
Server Port: 80
Date/Time
PHP Timezone: America/Chicago
PHP Time: Fri, 02 Nov 2012 07:38:06 -0500
System Time: Fri, 02 Nov 2012 07:38:06 -0500
Nagios XI Data
nagios (pid 23341) is running...
NPCD running (pid 1959).
ndo2db (pid 2011) is running...
CPU Load 15: 3.75
Total Hosts: 1252
Total Services: 570
The update to 2012R1.1 was straight forward and without incident.
Using the wizard, I reconfigured the oracle checks and noticed all arguments were placed in ARG1. I manually corrected to match the command string and spread the command inputs across all 8 arguments for my configuration to make it easy for my DBAs to use.
The command works from the command line, by the way nice option 'TEST CHECK COMMAND' in the new configuration interface!
I get an error from the web interface: [STDERR][EC 127]/bin/sh: /usr/local/nagios/libexec/env: No such file or directory ?
Your comments and suggestions are welcome. Thanks in advance.
Marcus
Oracle check problem after upgrade to 2012R1.1
Re: Oracle check problem after upgrade to 2012R1.1
[root@nagprod01 ~]# which env
/bin/env
This may be useful also
[root@nagprod01 bin]# cd /usr/bin
[root@nagprod01 bin]# ls -lrt *env
-rwxr-xr-x 1 root root 26280 Dec 7 2011 printenv
lrwxrwxrwx. 1 root root 13 Jun 6 16:01 env -> ../../bin/env
/bin/env
Can you PM me your commands.cfg file?
Just sent it.
Boy the command looks right, the only thing I can think of is if we had a second instance of nagios running trying to use an old command (like it hasn't applied)
Can we reset nagios
Can we reset nagios
service nagios stop
killall -9 nagios
service nagios startRe: Oracle check problem after upgrade to 2012R1.1
Done, but no change. I guest you probably knew you would not get off the hook that easy
Ok, let first offer a thousand apologies for my lack of brains.
I downloaded and install the oracle plugins on my 3 slave boxes in our DNX architecture. Problem resolved.
Sorry, Marcus
Sorry, Marcus
