Hello all,
i have a strange bug since upgrading form R3.2 to R3.3
Under Host => Performance Graphs every graph is showing up perfectly fine:
(Memory Usage, Drive C: Disk Usage)
When i go under the specific Service and go to Performance Graphs, this also works for every service except for the Drive C:\Disk Usage service:
Memory Usage
Drive C:\ Disk Usage
I have noticed that this doesnt work since R3.3 for every service that has a ":" character in the service name. Under R3.2 this was no problem!
Any suggestions how to fix it?
Kind Regards
No performance graphs were found for this service
Re: No performance graphs were found for this service
This was a bug in 3.3 that has been fixed in the latest release
Thanks for the quick response. I looked at the 2012 changes and found it.scottwilkerson wrote:This was a bug in 3.3 that has been fixed in the latest release
I thought i could wait with the upgrade to 2012 so i didn't looked there.
Seems i have to update now
