centos 6.3 64bit
manual install of XI - 2012R1.1
no special config
I'm using NRDS to use passive checks of my windows servers which works fine.
the issue I see is that I get "No performance graphs were found for this service." on any of the passive checks.
Is this data even available if not is there a way to graph the data other than using active checks.
active checks do build the graphs.
NRDP and Performance Graphs Windows
Re: NRDP and Performance Graphs Windows
NRDS will process performance data just fine however I think the default plugins used in NRDS for windows do not return performance data. I'm going to check with the developer to see if he knows of any that return performance data that could be used..
awesome! thank you
blariv,
Which plugins did you want to return perf data? The ones included don't include perf data as scott mentined, but some on exchange do.
for example:
http://exchange.nagios.org/directory/Pl ... at/details
When you run the command manually, everything after the pipe is processed as perf data
For example:
[test@nagios ~]# /usr/lib/nagios/plugins/check_nrpe -H 10.0.0.2 -c check_disk_iostat
Disk iostat| 0 C:AvgDiskQueueLength=0 DiskReadBytesPersec=0 DiskWriteBytesPersec=0 PercentDiskTime=0
Regards,
-Yancy
for example:
For example:
Regards,
-Yancy
thank you but I was looking for disk space, CPU and memory
I believe this one plugin can be used for all 3
http://exchange.nagios.org/directory/Pl ... TK/details
thanks, the problem is i need them to be passive running on the windows side, as VBS, pshell or .exe's
the native nrpe active checks show me performance data
It is...blariv wrote:thanks, the problem is i need them to be passive running on the windows side, as VBS, pshell or .exe's
You can download a zip containing check_pdm.exe here
just awesome, thank you soooo much for the fast help. works great!
