Nagios XI Exchange 2010 Wizard
We are demo'ing the XI version and are thinking about buying but there are issues needing to be resolved.
When using the wizard to add Exchange 2010 Servers i have failures for
MSExchangeImap4,MSExchangeIS,MSExchangeMailboxAssistants,MSExchangeMailSubmission,MSExchangeMonangePop3,MSExchangeRepl,MSExchangeSA,MSExchangeSearch,MSExchangeServiceHost,MSExchangeTransport,MSExchangeTransportLogSearch,msftesql-Exchange
These services do exist and are running on the servers but the wizards shows failures...
MSExchangeADTopology: Started - MSExchangeAntispamUpdate: Started - MSExchangeEdgeSync: Started - MSExchangeFDS: Started - MSExchangeIS: Not found - MSExchangeMailboxAssistants: Not found - MSExchangeMailSubmission: Not found - MSExchangeRepl: Not found -
Re: Nagios XI Exchange 2010 Wizard
from the command line on the windows machine can you run the following
sc queryex type= service state= all | find "MSExchangeIS"Re: Nagios XI Exchange 2010 Wizard
sc query type= service state= all | find "MSExchan
geIS"
SERVICE_NAME: MSExchangeISRe: Nagios XI Exchange 2010 Wizard
Ran for all missing Services only one that fails to lookup anything is MSExchangeMonangePop3 and since we dont use POP I would expect that..
E:\Exchange\Bin\perf\AMD64\en>sc query type= service state= all | find "MSExchan
geMailSubmission"
SERVICE_NAME: MSExchangeMailSubmission
geMailboxAssistants"
SERVICE_NAME: MSExchangeMailboxAssistants
geRepl"
SERVICE_NAME: MSExchangeRepl
geSA"
SERVICE_NAME: MSExchangeSA
geSearch"
SERVICE_NAME: MSExchangeSearch
geServiceHost"
SERVICE_NAME: MSExchangeServiceHost
geTransport"
SERVICE_NAME: MSExchangeTransportLogSearch
geTransportLogSearch"
E:\Exchange\Bin\perf\AMD64\en>sc query type= service state= all | find "msftesql
-Exchange"
SERVICE_NAME: msftesql-Exchange
I reversed the services in the command and it is successful for said services Which means the command is getting truncated some where.
Also msftesql-Exchange is a manual start so how would it successfully query such a process and this process was currently running but the successful query says stopped..I tried adding all the Not Found services to the front of the command and they still dont resolve correctly.
And the services status is truncated in the status information window.
What version of NSClient are you using?
NSClient++-0.3.9-x64.zip
Any Ideas on this?
I have been unable to replicate this issue. For the time being can we split the list into 2 services?
well yes but it would be like 8 services as the Exchange wizard set the option of checking all available Exchange services as one query.
Let me test just ones that fail by themselves.
