nagios check sun cluster failover
bluethundr
Post by bluethundr »
I was wondering if someone could suggest either a nagios plug-in or approach that would allow us to check if a sun cluster node FAILS OVER to another node. I've seen the sun_cluster check and some others but they appear to only check components of sun cluster. I could be mistaken as to whether this check can help you identify a failover from one node to another and if I am I welcome the correction. Thanks!
Re: nagios check sun cluster failover
Post by slansing »
Hmm, I am not able to find any plugins quite like what you are looking for beyond what users and our team have uploaded to the exchange. Could this possibly be achieved by using plugins designed not specifically for a Sun Cluster but could be tweaked?
