After upgrade to Nagios XI 2012, Email-alert duplicated?!
After upgrade to Nagios XI 2012, all the Email-alert messages sent twice! how to find out the problem?
Re: After upgrade to Nagios XI 2012, Email-alert duplicated?
This is likely related to a dual cron bug that should be fixed in 2012R1.2
You can run the following to fix the problem
crontab -l -u nagios | grep -v /usr/local/nagiosxi/cron | crontab -u nagios -
