Lock Notification Times
isadmin
Post by isadmin »
What is the easiest way to lock users from changing their notification times?
We are using Nagios XI fully patched VM download image. We imported our old Nagiox 3.x templates into the new server.
Re: Lock Notification Times
If you are using 2012 you can go to Admin -> Notification Management
Then, on the "Notification Options" tab check
"Check this box if you want to deploy the notification settings below. "
Enable Notifications:
Lock Notification Settings:
Select other settings and choose who to deploy them to.
this will make the settings unchangeable by the users
isadmin
Post by isadmin »
Thanks! Got it....
