HI
How do I change the index page and the menu
Where are the files in which directory?
You can change or sourceguardia can not edit files?
thanks
nagios xi change php index
Re: nagios xi change php index
Why?
Currently it should be sufficient to use CSS to alter the appearance of NagiosXI. Please let us know of any changes we can make for you, none who have receved this advice have stated that it was inadequate.
http://www.tbs-sct.gc.ca/clf2-nsi2/tb-b ... cc-eng.asp
http://articles.sitepoint.com/category/css
http://www.aaronsw.com/weblog/000169
diegosiassb
Hello I need to change some items in the menu
and I need to add menu items links that call other applications of our company.
This is because I want the page nagios is a reference for all my business even if you do not use the nagios
This allows you to show to show my work to a good part of my business and all levels.
Diego
Diego
diegosiassb
I enclose an example of the old nagios
Diego
Diego
Am I correct in assuming you just want to change the names of the links and menu items? If so, I can probably point you to the files and line #'s of where those changes need to be, but I'll make sure to say it now, that if you break something by changing the PHP we're not obligated to fix it for you since that's outside of our typical support package.
Are you talking about internationalization? We should instead implement a translation initiative, do things the correct way from day one. Please submit a translation and we can then include it in the next release. Please keep in mind I at least only know that multilingual users submit a translation, but beyond that I'd be unable to translate anything. We need to learn how translations work and how to implement them without any one teaching us how, making this hard. There are far more English teachers then there are developers that even understand this process.
As for adding menu items this can be done using our plugin system, to be documented and examples are available.
