I opened a topic for Locking Notification Times and it seemed Simple http://support.nagios.com/forum/viewtop ... ock#p37970
but I am receiving errors when attempting to apply it...
Username does not have a valid timeperiod for deployment. The timeperiod will have to be configured from the Core Config Manager.
Username does not have the XI notification handlers defined. Update the 'Notification Commands' for this contact in the Core Config Manager for new settings to be used.
I change these settings in the core config manage under contacts>> Alert Settings ...but it errors...
>>Error: Name or alias for timeperiod is NULL
Error: Could not register timeperiod (config file '/usr/local/nagios/etc/timeperiods.cfg', starting on line 27)
Lock Notification Times Errors
Re: Lock Notification Times Errors
Can you go to Configure -> CCM -> Time Periods and click the disk icon next to one of the (they all load the same file), then attach that file here.
Whats appears to have happen is I ran the NotificationMangement Wizard an it corrupted the user settings/failed to update them.
We want users locked to 24x7 notifications but only for Down, Unknown, Critical.
When I run the wizard and it throws time period errors and sets all the users selected to the opposite setting....r,f,s,n,w, under host and service notification options..
I have to go back and manually clean up everything....
I finally got the Config to apply but here is the Time Periods File...I also had to create a new 24x7 time period...and use it for applying... but it looks oddly strange in the PHP file
the xi_24x7 was causing failure.
If I mark it active I receive this error
Processing object config file '/usr/local/nagios/etc/timeperiods.cfg'...
Warning: Duplicate definition found for timeperiod 'xi_timeperiod_24x7' (config file '/usr/local/nagios/etc/timeperiods.cfg', starting on line 277)
Error: Could not add object property in file '/usr/local/nagios/etc/timeperiods.cfg' on line 278.
IF I deactivate it the config applies successfully.
Heres is Timeperiods PHP file
# Timeperiod configuration file
# Created by: Nagios QL Version 3.0.3
# Date: 2012-11-13 21:54:51
# Version: Nagios 3.x config file
# Nagios QL will overwite all manual settings during the next update
define timeperiod {
timeperiod_name 24x7
alias 24x7
name 24x7
define timeperiod {
timeperiod_name 24x7_sans_holidays
alias 24x7 Sans Holidays
friday 00:00-24:00
thursday 00:00-24:00
wednesday 00:00-24:00
tuesday 00:00-24:00
monday 00:00-24:00
sunday 00:00-24:00
use us-holidays
saturday 00:00-24:00
define timeperiod {
timeperiod_name user3_notification_times
alias Notification Times for user3
tuesday 00:00-24:00
friday 00:00-24:00
monday 00:00-24:00
sunday 00:00-24:00
define timeperiod {
timeperiod_name user2_notification_times
alias user2_notification_times
define timeperiod {
timeperiod_name user1_notification_times
alias Notification Times for user1
tuesday 00:00-24:00
friday 00:00-24:00
monday 00:00-24:00
sunday 00:00-24:00
define timeperiod {
timeperiod_name lnxdbBackup
alias lnxdb Backup Hours
sunday 07:00-20:00
monday 07:00-20:00
tuesday 07:00-20:00
wednesday 07:00-20:00
thursday 07:00-20:00
friday 07:00-20:00
saturday 07:00-20:00
define timeperiod {
timeperiod_name nagiosadmin_notification_times
alias Notification Times for nagiosadmin
tuesday 00:00-24:00
monday 00:00-24:00
sunday 00:00-24:00
friday 00:00-24:00
define timeperiod {
timeperiod_name nagiostestadmin_notification_times
alias Notification Times for nagiostestadmin
monday 00:00-24:00
tuesday 00:00-24:00
friday 00:00-24:00
sunday 00:00-24:00
define timeperiod {
timeperiod_name nagiostestuser_notification_times
alias Notification Times for nagiostestuser
monday 00:00-24:00
tuesday 00:00-24:00
friday 00:00-24:00
sunday 00:00-24:00
define timeperiod {
timeperiod_name none
alias No Time Is A Good Time
define timeperiod {
timeperiod_name non_support_hours
alias Non-Support Hours
sunday 00:00-06:00,16:00-24:00
monday 00:00-06:00,20:00-24:00
tuesday 00:00-06:00,20:00-24:00
wednesday 00:00-06:00,20:00-24:00
thursday 00:00-06:00,20:00-24:00
friday 00:00-06:00,20:00-24:00
saturday 00:00-06:00,16:00-24:00
define timeperiod {
timeperiod_name router_support
alias r_support
sunday 06:15-20:00
monday 06:15-20:00
tuesday 06:15-20:00
wednesday 06:15-20:00
thursday 06:15-20:00
friday 06:15-20:00
saturday 06:15-20:00
define timeperiod {
timeperiod_name sai_support_hours
alias App Support Hours
sunday 06:15-16:00
monday 06:15-20:00
tuesday 06:15-20:00
friday 06:15-20:00
saturday 06:15-16:00
define timeperiod {
timeperiod_name support_hours
alias Support Hours
monday 07:00-18:00
tuesday 07:00-18:00
wednesday 07:00-18:00
thursday 07:00-18:00
friday 07:00-18:00
saturday 07:00-12:00
define timeperiod {
timeperiod_name us-holidays
alias U.S. Holidays
name us-holidays
january 1 00:00-00:00
monday 1 september 00:00-00:00
july 4 00:00-00:00
thursday -1 november 00:00-00:00
december 25 00:00-00:00
define timeperiod {
timeperiod_name weekday_hours
alias weekday_hours
monday 06:00-18:00
tuesday 06:00-18:00
wednesday 06:00-18:00
thursday 06:00-18:00
friday 06:00-18:00
define timeperiod {
timeperiod_name workhours
alias Normal Work Hours
monday 09:00-17:00
tuesday 09:00-17:00
wednesday 09:00-17:00
thursday 09:00-17:00
friday 09:00-17:00
# END OF FILE
Run the following command in terminal:
...then Apply Configuration.
Hope this helps.
curl -s http://assets.nagios.com/downloads/nagiosxi/scripts/fix_static_import| mysql -pnagiosxi nagiosqlHope this helps.
Thanks still receiving errors on applying Notifications management lockdown
This occurs for every user selected to be locked down
OK so figured out the time periods for lock down only work with the user_specific notification timeperiod and I set that....so one error gone
still receiving
testUser does not have the XI notification handlers defined. Update the 'Notification Commands' for this contact in the Core Config Manager for new settings to be used.
but I do have the xi_host_notification_handler under the host settings for the user and the xi_service_notification_handler under the service setting...
still receiving
tested on a second user and all succeeds? With the exact same settings?
The xi_host_notification_handler & xi_service_notification_handler are not host/service handlers
They need to be set in the CONTACT's
I must have been missing something. Everything is working now.
Thanks Scott!
Thanks Scott!
