On both installs, I am noticing errors like the ones below:
Nov 13 16:01:50 scnagiosxi ndo2db: mysql_error: 'Table './nagios/nagios_timedeventqueue' is marked as crashed and should be repaired'
They will be preceded by an error in trying to insert or delete from that table, for example:
Nov 13 16:01:50 scnagiosxi ndo2db: Error: mysql_query() failed for 'DELETE FROM nagios_timedeventqueue WHERE instance_id='1' AND event_type='1' AND scheduled_time=FROM_UNIXTIME(1352851309) AND recurring_event='1' AND object_id='0''
I was wondering what the best way to repair that table is?
Also why would both instances get the same error at the same time? Are there any reasons why this would have happened to both installs, and are there any steps we can take to help avoid it happening again?
The system's info is below. Thanks!
Edit - I had to remove the URLs from the Admin->System Profile info as the forum would not allow that many URLs to go in to this post.
1) CentOS, version 6.3
2) 64 bit
3) VMware Image
4) Admin->System Profile info:
Nagios XI Installation Profile
Download Profile
System:
Nagios XI Version : 2012R1.2
scnagiosxi.pfsc.local 2.6.32-279.9.1.el6.x86_64 x86_64
CentOS release 6.3 (Final)
Gnome is not installed
Apache Information
PHP Version: 5.3.3
Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:16.0) Gecko/20100101 Firefox/16.0
Server Name: scnagiosxi.practicefusion.com
Server Address: 10.11.13.22
Server Port: 80
Date/Time
PHP Timezone: America/Chicago
PHP Time: Tue, 13 Nov 2012 17:58:27 -0600
System Time: Tue, 13 Nov 2012 15:58:27 -0800
Nagios XI Data
nagios (pid 30116) is running...
NPCD running (pid 1797).
ndo2db (pid 1861) is running...
CPU Load 15: 1.74
Total Hosts: 85
Total Services: 1593
Function 'get_base_uri' returns: SNIP
Function 'get_base_url' returns: SNIP
Function 'get_backend_url(internal_call=false)' returns: SNIP
Function 'get_backend_url(internal_call=true)' returns: SNIP
Ping Test localhost
Running:
/bin/ping -c 3 localhost 2>&1
PING localhost (127.0.0.1) 56(84) bytes of data.
64 bytes from localhost (127.0.0.1): icmp_seq=1 ttl=64 time=0.030 ms
64 bytes from localhost (127.0.0.1): icmp_seq=2 ttl=64 time=0.029 ms
64 bytes from localhost (127.0.0.1): icmp_seq=3 ttl=64 time=0.033 ms
--- localhost ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 1999ms
rtt min/avg/max/mdev = 0.029/0.030/0.033/0.006 ms
Test wget To locahost
WGET From URL: http://localhost/nagiosql/index.php
Running:
/usr/bin/wget http://localhost/nagiosql/index.php
--2012-11-13 15:58:29-- http://localhost/nagiosql/index.php
Resolving localhost... ::1, 127.0.0.1
Connecting to localhost|::1|:80... connected.
Length: 5259 (5.1K) [text/html]
Saving to: `/tmp/nagiosql_index.tmp'
0K ..... 100% 582M=0s
2012-11-13 15:58:29 (582 MB/s) - `/tmp/nagiosql_index.tmp' saved [5259/5259]
