Guys in one of my posts I asked if it was possible to uninstall Nagios.
http://support.nagios.com/forum/viewtop ... f=6&t=7102
lmiltchev created the most excellent script that does that perfectly. I made an addition to the script that will download and install the latest version of nagios.I tested it a few times and it seems to work.
lmiltchev created it, all i did was copy and paste the manual install instructions.
When I actually learn how to code I plan on adding an option that will ask you before it deletes a folder.
I would like to donate it to the community website , but I don't know how to other than adding it as an attachment here.
uninstall reinstall Nagios script
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
