Fusion installation using VMware Virtual Machine
lafargeuser
Is there any documentation available to installed Nagios Fusion VMware Virtual Machine (32 bit).
refering below link.
http://library.nagios.com/library/produ ... /downloads
But not able to find any documentation.
Re: Fusion installation using VMware Virtual Machine
The Fusion VM is already pre-installed with Nagios Fusion. You can power on the VM in ESX ,Vmware Workstation, of Vmware player, fetch the IP address, and access the web install page at:
http://<theipaddress>/nagiosfusion
From there you'll want to review the following:
http://library.nagios.com/library/produ ... ios-fusion
lafargeuser
while power on it throws below error
Power On virtual machine UX_IMSLAB_NagiosFusion Device 'Hard disk 1' has a backing type that is not supported. This is a general limitation of the virtual machine's compatibility with the ESXi version of the selected host.
import is failing
import is failing
What version of ESX are you importing into?
lafargeuser
ESX 5.1
Also tried to installing manually. below pasted is install.log
Nagios Fusion Installation Log
DATE: Thu Nov 22 12:55:24 IST 2012
DISTRO INFO:
CentOS
5.5
i686
THIS IS A NEW INSTALL!
INSTALLING:
full=2012R1.1
major=2012
minor=R1.1
releasedate=2012-06-28
release=201
Configuring Yum...
Enabling RPMForge repo...
Installing RPMForge PKG: packages/rpmforge-release-0.5.2-2.el5.rf.i386.rpm
warning: packages/rpmforge-release-0.5.2-2.el5.rf.i386.rpm: Header V3 DSA signature: NOKEY, key ID 6b8d79e6
Preparing... ##################################################
rpmforge-release ##################################################
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
Error: Cannot find a valid baseurl for repo: addons
Could not retrieve mirrorlist http://mirrorlist.centos.org/?release=5 ... epo=addons error was
[Errno 4] IOError: <urlopen error (101, 'Network is unreachable')>
rpmforge-release RPM installed OK
Enabling EPEL repo...
Installing EPEL PKG: ./packages/epel-release-5-4.noarch.rpm
warning: ./packages/epel-release-5-4.noarch.rpm: Header V3 DSA signature: NOKEY, key ID 217521f6
epel-release ##################################################
epel-release RPM installed OK
Yum configured OK
Installing prerequisites...
if my understading is correct, then do we require to have internet download access to on which we are going to install NagiosFusion.
DISTRO INFO:
CentOS
5.5
i686
INSTALLING:
full=2012R1.1
major=2012
minor=R1.1
release=201
Configuring Yum...
Yum configured OK
Yes, it is required for a full install to download required packages.lafargeuser wrote:if my understading is correct, then do we require to have internet download access to on which we are going to install NagiosFusion.
lafargeuser
With proxy it was not working. So i use NAT IP instead & was able to download pkgs from internet.
Now can i have repository for the all pkgs so that in future if i would need to install Fusion,then i will be using same repository so that it will locally get installed. And i dont have to opt for NAT IP or internet download access.
We've got some notes on using wget and yum behind a proxy, this could be useful for your scenario:
http://support.nagios.com/wiki/index.ph ... th_Proxies
lafargeuser
I had tried that setting as well but didnt work.
Thanks.
Installing NagiosXI & Fusion is very simple but getting internet download access its very tough in my enviroment due to software compliance.
There should be other way like Core, we can installed these products without internet or creating local respository.
Thanks.
Currently our solution for this has been recommending users download our pre-installed VM and import it into their virtualization server. Doing an offline installer for Fusion would be a lot simpler than XI. When we attempted to do this for XI by creating a tarball with a local package repository, we found that just about everyone who needed an offline installer had special requirements on their installation platform, which made it almost impossible to have have a supportable offline installer...
