Every new host I create using the CCM has the notification_enabled set to "off". Is there somewhere that I can change this to "skip" instead?
Running:
Nagios XI Version : 2012R1.2
CentOS release 6.3 (Final)
PHP Version: 5.3.3
New hosts have notification_enabled off
Re: New hosts have notification_enabled off
This is currently a bug if you leave the options blank when creating a new host, this will be fixed in the 1.3 release but for now if you just select "skip" when creating a new host it will save it the correct way.
Good to know.
Any idea when 1.3 comes out?
In the not to distant future, 1.2 was rolled out about a week ago but as more bugs get squashed we get closer to a worthy 1.3 release.
Thanks for the help. I'll be patient.
