Linux Dist: Cent OS 6.1 64 bits
Manual Install Nagios XI.
No specials configurations.
After Upgrade our systme to NAgios XI R1.2, we have some problems to activate new feautures, that previously we can..
Attached image.
need to perform further action?
thanks.
Problem After Upgrade to R1.2
Re: Problem After Upgrade to R1.2
http://support.nagios.com/forum/viewtop ... =16&t=7787
You can trial the Enterprise feature-set for 60 days under Admin-> License InformationA key difference with the release of 2012 is that there will be both an Enterprise Edition and a Standard Edition, with the Enterprise Edition being targeted at users with larger environments.
All active maintenance plans have upgrade capabilities to the Standard Edition with the option to upgrade to the Enterprise Edition. All 2012 version will have the capabilities to trial the new Enterprise features for 60 days.
Any questions on pricing for the Enterprise Edition should contact [email protected]
Hi scott,
my English is not very good, but that means we have to pay for this new release (R1.2)?
Thanks for the reply.
You don't have to pay additional for the same features you had before, but there are some enhancement that are not part of the Standard License and these have an additional cost..
Now I understand.
Thanks for everything, scott.
P.D: you can close the topic.
