Custom logo component
This support forum board is for questions relating to Nagios Fusion.
TBT
Post by TBT »
I installed the Custom Logo Component to Fusion but it does not make the appropriate changes, is this a bug or compatibility issue?
Note: It checks /usr/local/nagiosxi/html/images/ which isn't present in Fusion installs.
If the components are not compatible with Fusion, a check should be done to disallow the installation.
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
mguthrie
Re: Custom logo component
Post by mguthrie »
Agreed. However, Fusion components are listed separately from Nagios XI components on Nagios exchange, and generally XI components won't work in Fusion without some modifications.
We'll add it to the development TODO to make the component compatible for either XI or Fusion, and create a new listing on exchange when it's ready. I just checked the Fusion code, and currently it doesn't support the Custom Logo as of yet, but we'll get that added to the feature list for the next version release of Fusion as well. We've had this requested, as well as custom login pages for both XI and Fusion.
