Greetings,
Just insalled nagios 3.3.1 on openbsd 5.2. The web server apache is up and running and I can get the initial page.
Nagios installed to /etc/nagios/ In this directory, I can see the nagios.cfg main configuratin file.
I can start nagios from /usr/local/sbin/nagios start. When I execute the top command I see nagios running.
What other configuration I need to work on to get nagios to show on the web site:
Please, let me know! Thanks!
getting nagios to start
Re: getting nagios to start
Do you have an alias setup with apache to point to the Nagios web directory? Example for a RHEL-based system on a source install:
Apache config:
/etc/httpd/conf.d/nagios.conf
Directs all requests to http://<myserver>/nagios to:
/usr/local/nagios/share
Example nagios.conf for this setup:
Apache config:
# SSLRequireSSL
Options ExecCGI
AllowOverride None
Order allow,deny
Allow from all
AuthName "Nagios Core"
AuthType Basic
AuthUserFile /usr/local/nagiosxi/etc/htpasswd.users
Require valid-user
</Directory>
Alias /nagios "/usr/local/nagios/share"
<Directory "/usr/local/nagios/share">
# SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
AuthType Basic
Require valid-user
</Directory>-
[email protected]
Greetings,
Many thanks for your response: here is what I have in httpd.conf
Alias /icons/ "/var/www/icons/"
<Directory "/var/www/icons">
Options Indexes MultiViews
AllowOverride None
Order allow,deny
Allow from all
</Directory>
#Scriptalias/nagios /var/www/nagios
# ScriptAlias: This controls which directories contain server scripts.
# ScriptAliases are essentially the same as Aliases, except that
# documents in the realname directory are treated as applications and
# run by the server when requested rather than as documents sent to the client.
# The same rules about trailing "/" apply to ScriptAlias directives as to
# Alias.
ScriptAlias /cgi-bin/ "/var/www/cgi-bin/"
# "/var/www/cgi-bin" should be changed to whatever your ScriptAliased
# CGI directory exists, if you have that configured.
<Directory "/var/www/cgi-bin">
AllowOverride None
Options None
Order allow,deny
Allow from all
</Directory>
# Redirect allows you to tell clients about documents which used to exist in
# your server's namespace, but do not anymore. This allows you to tell the
# clients where to look for the relocated document.
# Format: Redirect old-URI new-URL
But to be honest with you I am not sure if that is the correct path that I should point to; how do I know that?
Here is more information about the directory structure:
main configuration files: /etc/nagios/nagios.cfg
Let me know! Thanks
AllowOverride None
Order allow,deny
Allow from all
</Directory>
# Alias.
AllowOverride None
Options None
Order allow,deny
Allow from all
</Directory>
Let me know! Thanks
