error in the ovf file
I downloaded the nagios product from http://assets.nagios.com/downloads/nagi ... 1.2-64.ova. After i uncompressed the file, i tried deploy\deploy ovf template and browsed to the ovf file. When i try to open the file i get "fails integrity check and may have been corrupted during transfer". I re downloaded the compressed file and uncompressed again but got the same error. any ideas. We are running the vshere 5.0 client
Re: error in the ovf file
You do not need to uncompress the file
You actually can just do the following from within vSphere
File -> Deploy OVF Template
Select nagiosxi-2012r1.2-64.ova from your computer
OR, you can just place the full URL in there
http://assets.nagios.com/downloads/nagiosxi/2012/ovf/nagiosxi-2012r1.2-64.ova
