How to Monitor EMC VNX
shakra2005
Post by shakra2005 »
Hi Guys,
we have 2 EMC VNX 5300 SAN and i want to monitor them with the XI EMC Wizard.
Now i have configured it with the wizard and i have same problems:
SPA and SPB Status specified port not found -1
not output from /opt/Navisphere/bin/navicli
Disks no disks were founded
Navicli is installed. When i check the SANS with the naviseccli can see all informations
can you help me
Re: How to Monitor EMC VNX
Is the client located at /opt/Navisphere/bin/navicli on your system?
If not you may need to change the paths on line 114, 115 of /usr/local/nagios/libexec/check_emc_clariion.pl
shakra2005
the Path is the right.
At this point I guess I would recommend contacting the Wizard creator as this is a 3rd party Wizard. He is a forum member Box293
