Nagios Noob question.
Angelo
Post by Angelo »
Hello everyone, I just recently started working with this company, and they are using Nagios. When we get alerts from config changes, what do the numbers at the end of the message mean? In this case the "1 3 2" :?
"Additional Info:
Notification of a configuration management event as 1 3 2"
Re: Nagios Noob question.
This is really going to depend on the check that the administrator setup. I am guessing this is a custom plugin.
Is this Nagios XI?
Angelo
Post by Angelo »
Thanks for the reply. I am not sure heh, under teh home tab it says Nagios version 2.12
I moved this to the Core forum as I believe that is what you have.
You will need to figure out what plugin this check is using before we would be able to help you with it.
