I have alot like 440 unhandled items in my Service status summery and 3 in my host summary but when I click on it I only get like 9 service and 3 host issues listed.
There are checks that dont belong to the devices they are checking. When I try and delete the bad service I get the error below....
I have checked the service check and the hosts with these issues are not listed.
Unhandled Problems not available and with Bad Unique ID's
Re: Unhandled Problems not available and with Bad Unique ID'
This sounds like it could be Ghost hosts/services
http://support.nagios.com/wiki/index.ph ... t_Hosts.29
didnt fix it? and the manually write files tool I see
Warning: Duplicate definition found for service '3G Interface Up' on host 'mob8' (config file '/usr/local/nagios/etc/services/_multiple_hosts_router_3g.cfg', starting on line 14)
Only problem is if I look at the file those old hosts dont exist in it?
sure but why a new ticket? and what should I call it?
Scott tried attaching snapshot on new ticket but its 21mb and appears to be popping some limit. It just resets the Form page when I try to upload it?
Actually I meant send an email to [email protected] with the attachment (which will create a new support ticket).
Resolved via email
