make all-recursive
make[1]: Entering directory `/downloads/nagios-plugins-1.4.16'
Making all in gl
make[2]: Entering directory `/downloads/nagios-plugins-1.4.16/gl'
make all-recursive
make[3]: Entering directory `/downloads/nagios-plugins-1.4.16/gl'
make[4]: Entering directory `/downloads/nagios-plugins-1.4.16/gl'
make[4]: Nothing to be done for `all-am'.
make[4]: Leaving directory `/downloads/nagios-plugins-1.4.16/gl'
make[3]: Leaving directory `/downloads/nagios-plugins-1.4.16/gl'
make[2]: Leaving directory `/downloads/nagios-plugins-1.4.16/gl'
Making all in tap
make[2]: Entering directory `/downloads/nagios-plugins-1.4.16/tap'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/downloads/nagios-plugins-1.4.16/tap'
Making all in lib
make[2]: Entering directory `/downloads/nagios-plugins-1.4.16/lib'
Making all in .
make[3]: Entering directory `/downloads/nagios-plugins-1.4.16/lib'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/downloads/nagios-plugins-1.4.16/lib'
Making all in tests
make[3]: Entering directory `/downloads/nagios-plugins-1.4.16/lib/tests'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/downloads/nagios-plugins-1.4.16/lib/tests'
make[2]: Leaving directory `/downloads/nagios-plugins-1.4.16/lib'
Making all in plugins
make[2]: Entering directory `/downloads/nagios-plugins-1.4.16/plugins'
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"1.4.16"' -g -O2 -MT check_http.o -MD -MP -MF .deps/check_http.Tpo -c -o check_http.o check_http.c
check_http.c: In function âmainâ:
check_http.c:150: warning: ignoring return value of âasprintfâ, declared with attribute warn_unused_result
check_http.c: In function âprocess_argumentsâ:
check_http.c:312: error: âssl_versionâ undeclared (first use in this function)
check_http.c:312: error: (Each undeclared identifier is reported only once
check_http.c:312: error: for each function it appears in.)
check_http.c:268: warning: ignoring return value of âasprintfâ, declared with attribute warn_unused_result
check_http.c:397: warning: ignoring return value of âasprintfâ, declared with attribute warn_unused_result
check_http.c: In function âcheck_document_datesâ:
check_http.c:693: warning: ignoring return value of âasprintfâ, declared with attribute warn_unused_result
check_http.c:696: warning: ignoring return value of âasprintfâ, declared with attribute warn_unused_result
check_http.c:703: warning: ignoring return value of âasprintfâ, declared with attribute warn_unused_result
check_http.c:706: warning: ignoring return value of âasprintfâ, declared with attribute warn_unused_result
check_http.c:709: warning: ignoring return value of âasprintfâ, declared with attribute warn_unused_result
check_http.c:714: warning: ignoring return value of âasprintfâ, declared with attribute warn_unused_result
check_http.c:717: warning: ignoring return value of âasprintfâ, declared with attribute warThanks in advance.
