Resize grafh in dashboard
CBoekhuis
Post by CBoekhuis »
after succefully upgrade to Xi 2012R1.3 i discovered that resize a grafh on the dashboard doesn't work completely.
The grafh doesn't refresh automaticly after resize. To see the resized grah you have to reopen the dashbord.
Resizing inr the gafher works dynamically.
Regards
Christian
mguthrie
Re: Resize grafh in dashboard
Post by mguthrie »
Is this a graph made from the "All Host Graphs" section, or the Graph Explorer component?
CBoekhuis
Post by CBoekhuis »
from the grafh explorer.
mguthrie
Post by mguthrie »
Graph Explorer dashlets work differently than most other dashlets since it's more than just resizing an html <div>. The vector image has to be reloaded, so if you resize the dashlet the graph should resize after the data refreshes (every 30 seconds) or from reloading the dashlet.
