Custom Logo feature
TBT
Custom Logo feature
Post by TBT »
Can we get an option in the Custom Logo Settings to disable opening the URL in a new window? Ideally taget=blank would be off by default and toggled by a check box.
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
Re: Custom Logo feature
Post by slansing »
Hello TBT,
This is currently not changeable but you can add a feature request at:
http://tracker.nagios.org/
TBT
Post by TBT »
Password recovery feature on tracker isn't accepting my information, even though it is identical to the original registration.
APPLICATION ERROR #1903
The provided information does not match any registered account!
Post by slansing »
Try the .com version, I mistakenly posted the Nagios Core version to you:
http://tracker.nagios.com/
I took care of the feature request posting just now.
Update: It has been patched in and you will be able to change the target when 1.3 releases, which should be within the month.
TBT
Post by TBT »
Made the request hours ago, never received the reset email (Yes, check if it was flagged as spam).
Update: Thank you, but I still require access to tracker.
mguthrie
Post by mguthrie »
Every once in a while the hosting server that machine is on gets on a blacklist somewhere. Checking on that now to see if that's what happened again...
TBT
Post by TBT »
I noticed when checking for component updates, Custom Logo (Version: 1.0) can be updated to 1.1, but still reports version 1.0 once upgraded.
Also, above it was mentioned the feature request would be available in 1.3, where is 1.2?
Actually it will be available in Nagios XI 2012R1.3 not custom logo version 1.3...
we also found a bug (will be fixed in the next release as well) that will not let you upload new components if you just checked for updates.
Navigate away from the Manage components page and then back to it
Upload component (without clicking "Check for Updates")
Nagios XI 2012R1.3 will likely be released withing the week
TBT
Post by TBT »
I assume you're keeping the components and dashlets in Nagios XI releases in sync with what is offered on exchange, correct?
That's correct.
