Hi
Can anyone help me out. Can I monitor windows machines without installing NSCLIENT tool or any other third party tool. If yes, then can you explain me the procedure along with the configurations.
Helpers appreciated Thank you*
How to monitor windows machines without installing NSCLIENT
listening723
Re: How to monitor windows machines without installing NSCLI
I can't give you specific details considering I do use the agent, but there are several interfaces available to you... though they are all far more limited. You could enable active SNMP on all your windows hosts, you could configure SNMP traps on all your windows hosts or you could use check_wmi_plus.
It's probably worthwhile stating what monitoring you require on windows as that will most likely dictate the most appropriate stand-in for the client.
I only use SNMP to monitor remote hosts, this is a default service in windows, you just have to enable it
google how to enable snmp and you will find a guide for sure..
listening723
I have already installed snmp service in host but do I need to make any changes in windows.cfg file.
For Example for nsclinet we use the following configuration
host_name ERMS8-HP
service_description NSClient++ Version
check_command check_nt!CLIENTVERSION
Do I need to change any lines in the above to monitor host using snmp.
And Do i need to install any pulgin in nagios to monitor hosts using snmp.
host_name ERMS8-HP
listening723 wrote:I have already installed snmp service in host but do I need to make any changes in windows.cfg file.
host_name ERMS8-HP
Yes.
You need to set up a command that executes your snmp script, and then a service for binding that command to a host.
Please see nagios config guides for this, there are good tutorials on the web
