Do I have to manually add all the Windows servers to the windows.cfg file, or is there an easier method? I did not see a way through the web GUI.
-=Raj=-
Add Windows servers via the GUI?
tonyyarusso
Re: Add Windows servers via the GUI?
With Nagios Core, generally yes. XI includes wizards for this sort of thing, but Core's configuration is usually done by hand (unless you write your own scripts / Puppet recipes for adding things).
OK. Thank you for the reply.
Has anyone written a cool plugins to add Windows servers?
-=Raj=-
-=Raj=-
